upholstery replacement
Discussion in 'General Maintenance & Repairs' started by Craig Birchfield, Sep 25, 2018.
  1. Craig Birchfield
    Craig Birchfield New Member
    3
    Waxhaw, NC
    2004 220
    5.0 V8
    2014 Chevy Truck
    i bought a used 2004 220, boat sat in sun for 10 years, interior upholstery is dry rot. is there a replacement kit or must individual items be custom replaced?
  2. Walt P
    There are no replacement covers for older boats. Use a local Upolstery shop. Depending where you are, there could be a few.
  3. David Bleil
    David Bleil New Member
    7
    PGH pa
    1995 252
    502
    F250 Super Duty
    Does anyone know what manufacturer Cobalt used for vinyl in 1995
  4. Walt P
    The vinyl now is much better and thicker than what was used back then. I wouldn’t look for OEM for vinyl.
  5. Anonen
    Anonen New Member Founding Member
    4
    Minnesota
    502 MAG
    Yukon Denali
    I agree with Walt about the newer vinyl. You can find rolls of Cobalt OEM vinyl on Great Lakes Skipper. If nothing else, you can get an idea of the color and texture and have a local upholstery shop match it for you.
    https://www.greatlakesskipper.com/oem-parts-and-accessories/cobalt-boats
  6. Muggsy
    I replace the vinyl on my '85 CM23 with products from Sailrite. www.sailrite.com
  7. davidh
    davidh New Member
    4
    Lake Winnipesaukee
    2003 Cobalt 240
    350 MPI
    2004 24 foot bow rider any idea what a total vinyl replacement should be ?
  8. Muggsy
    David, I don’t. I can only tell you what I paid. I bought my vinyl from Sailrite for about $400. I then found a local seamstress to work with that did upholstery. I removed all of the pieces to be recovered (seats, side panels, etc.), took them apart and removed the old skins and took them all to her. She and I designed the layout of the new skins and she sewed everything. She charged me $1200. I put most of the skins on myself but got some help from an upholstery shop for a few pieces for $300. I then put everything back in myself. If you are having it all done at a shop I would think you will pay somewhere between $2000-$4000. Taking all of the pieces out yourself will save you a bit.
