/ Register
Prop size 95 cobalt200
Discussion in 'Engines, Drives, Props, etc.' started by Soggydog, Sep 25, 2017.
  1. Soggydog
    Soggydog New Member Founding Member
    2
    Cincinnati Ohio
    1995 cobalt200
    5.0 vpdp
    I purchased a 95 cobalt200 with a Volvo penta 5.0 dp at the beginning of this season and it has ss props that I damaged. Now I’m looking for a new set and don’t know what size I should get so I’m looking for recommendations. Does anyone have the same setup that would like to help me out? Thanks
  2. Walt P
    Depending on how damaged they are, you may be able to have them resurfaced/repaired at a much lower cost than replacement. For my 262, it cost me about $350 for resurfacing (there was a huge nick on one of the blades) versus $1200 for new props. I would check in your area for someone that does it.
  3. Soggydog
    2
    Cincinnati Ohio
    1995 cobalt200
    5.0 vpdp
    Thank you I plan on getting them fixed but I need to get another set Incase I destroy a set. The Ohio River can be unforgiving! Thank you
  4. thunder550
    thunder550 Well-Known Member
    Aug 14, 2017
    Scottsdale, AZ
    1995 Cobalt 252
    502 Mag EFI
    2017 GLE43
    If you are looking for factory replacements, the OEM prop specs are called out in the owners manual. Screenshot attached from the 1995 manual. These manuals are available for download from cobaltboats.com too.
